Info on Wizard Garden Tractor
Creek Critter
09-08-2003 13:27:04
Trying to find year of manufacture on 16 HP Western Auto Wizard. Hydrostatic Drive-hand controlled. Hydraulic lift with 3 point hitch. Made by MTD. 16 HP Briggs horizontal shaft engine. No coil on engine. Magneto only.
clifford c benjamin
09-26-2003 07:08:43
 Re: Info on Wizard Garden Tractor in reply to Creek Critter, 09-08-2003 13:27:04
16 hp inteck engine in this tractor?the three numbers on the engine will tell you the year that the engine was made not the tractor but it will be close check j.c.whitney web site.they have somrthing to do with western auto.also mtd made the tractor.web site for mtd pro is www.mtdpro.com phone is 1- 330 -225 -2600 clevend ohio.also under the seat there should be a tag with model serail number or below the seat the metal fender that goes over the rear tires there also be where the tag is if it hasent been pressured off.
Steve Johnson
09-08-2003 20:47:36
Look for the numbers stamped to the shroud of the engine. The code number is the one that you are looking for. The first two digits are the years the engine was built. The second two are the month and the third two are the day it was built. I hope that helps.
CreekCritter
09-09-2003 09:27:05
 Re: Re: Info on Wizard Garden Tractor in reply to Steve Johnson, 09-08-2003 20:47:36
Thanks for the info Steve. really appreciate it.
