Need info on Peerless transmissions
R Wyler
01-29-2003 16:54:35
I need to replace the transmission on my old Montgomery Ward ridy mower it has a vertical shaft engine the engine drives a pully on the bottom of the transmission and there is a drive sproket with a chain on the side of the gear box. Can I still by a gear box made like this? Thanks for any help. Richard.
chuck kurrus
08-22-2005 05:18:47
 Re: Need info on Peerless transmissions in reply to R Wyler, 01-29-2003 16:54:35
i've got a poulan autoimatic lawn tractor, hydro tranmisson, won't pull right. put it in drive, goes very slow, no guts, will not pull up a slight grade. need help. is there a quick fix? anything other than replacing the uint? any help would be appreciated. thanks
chuck.
badassmagilla@excite.com
Green Dean
01-30-2003 06:48:27
Peerless is part of Tecumseh, if you haven't already been told. So that is the place to look.
R Wyler
01-30-2003 08:29:40
 Re: Re: Need info on Peerless transmissions in reply to Green Dean, 01-30-2003 06:48:27
Thanks I noticed that they are connected. Richard.
Gene Davis
01-29-2003 21:00:33
Look in your E-mail box. Sent you an e-mail on this. Gene Davis
R Wyler
01-30-2003 06:18:27
 Re: Re: Need info on Peerless transmissions in reply to Gene Davis , 01-29-2003 21:00:33
Gene I sent you an e-mail I will get the details on sizes and deminsions today. Richard.
