'90 Wheelhorse 416-8 problems
shortlid
04-27-2002 22:20:45
I have a 1990 416-8 with 1800 hours on it. The single cyl. Kohler command has had a valve job and a built carb. The 48 in. tri-blade deck is in hurting shap it has been welded on tweenty times or so! recently there is a rubbing sound from around the running boards the belt is rubbing somewhere? And every winter it kills a battery!!Mike from the wheelhorse club, e-mail me can you at shortlid@purdue.edu so I can ask you some questions?
Sonja Aktas
03-18-2005 23:04:09
 Re: '90 Wheelhorse 416-8 problems in reply to shortlid, 04-27-2002 22:20:45
I have a 1986 416-8 and i need the elektricmap.
Please can you help me.
Thanks and a nice day .
Ali and Sonja Aktas.
Austria/Vienna
shortlid
04-29-2002 09:57:38
The drain plug on the uni-drive also leaks real bad? It is as tight as i can get it?
