Wheel Horse Charger 12
buzzinduzzin
Location
se illinois
On the right side there is a v belt that goes from the engine crank pulley to the pulley/cooling fan on the input shaft of the hydrostat drive unit ( Sunstrand ? ) , there is a lever controlled idler pulley that controls the tension of the v belt. According to the owners manual (downloaded from the net ) the pulley is # 7434 . the current pulley has with paint marker pen # 34012 . where can I purchase this pulley & for that matter ; gaskets, seals & O rings for this Wheel-a-Matic transmission ? It has developed a leak & I am in the process of trying to locate source . Last but not least, on the hydraulic drive control : Nylon cam with these 3D printers is anyone making this cam ? TIA
Sten has a lot of those kinds of pulleys. Might be worth your time. I needed an idler pulley for my JD 110 and they had it.
Look on the Redsquare Wheelhorse forums.Lots of info and sources on there.The pulley you need though is just a
generic idler,you can find one by size anywhere.Biggest thing to look for is the offset.Make SURE it is the same as
yours before you order one.
The oil leak was the swash plate shaft O ring , it was pretty hard. A new 3/32 X 3/4 ID appears to have worked. Will look for pulley etc. after Thanksgiving
