the tractor vet
Finished up the get me running stage last evening . Changes made to it were new ing. switch a total up grade to the lighting that include new L E D lights ft. and back , L E D strobe flashers ft . and back , L E D rear work lights , new hydo unit fan and new motor mounts that i made . Took a bit of R & D several staff meetings and two porto type designs and they work vary well and for a cost of 22 bucks . And some fine tuning of the hydo control to get it to center in neutral ,did away with the rear wheel bolts and it now had studs and wheel nuts , so much easier to remove and replace the back tires and wheels . and the steering box rebuild all new tie rod ends . Used the light switch from a 706 up for a three possession switch for dim with flashers and red rear then bright with flashers and red tail then last click ya have bright with out flashers and your rear work lights . Yea maybe a little over the top . Now still thinking on a back up beeper Around a 150 DB. one
