Swisher A-32B
jasonhooper
New User
Hello I m new on here I am looking for some information on those three wheel lawnmower I bought the other day it is a swisher big mow model A-32B Any information would be great and appreciate it thank you very much serial number Z-62665 :?:
I had 2 of the early model with 32 cut. You adjust the blade height by taking the blades off with the long and short bushings, then reassemble in an order that suits your height. An uphill climb requires leaning over the steering wheel for traction.
(quoted from post at 18:27:49 10/20/22) I had 2 of the early model with 32 cut. You adjust the blade height by taking the blades off with the long and short bushings, then reassemble in an order that suits your height. An uphill climb requires leaning over the steering wheel for traction.
Thank you lol I need all the Information that I can get thank you sir I had no idea
