whizkidkyus
- Location
- South Central , Ky.
In an earlier post about an electric pto bearing you mentioned removing a bearing lock in order to replace the bearing and relocking it in with a cape chisel . What size Cape chisel do you use or which will work best ? A 3/8 5/16 or a 3/16 ? Amazon lists several different sizes , mostly these three in particular as well as different manufacturing brands ! So with that being said any particular brand ? What brand of this chisel do you use or like best ? Care to describe a little on how you do it , remove the lock as well as reinstall it ? I work on small engines and this will be interesting to know ! I've never heard of a Cape chisel or this method !
Thanks for you help ,
Whizkid
