318 JD hydro lever position moves too easily
Roger in Iowa
Hydro lever wants to move too easily.. Going up hill it moves to slow the tractor, and going down hill it moves to speed the tractor. I know some is normal, speeding or slowing but you can see the lever move. Is there an adjustment? I see a 317 was adjustable. Holding the lever is a pain.
Remove the battery and the battery tray and you will see the friction pads and the nut to put more pressure on the hydro lever friction mechanism, the nut is accessed though the RH side of the steering/control pedestal.
(quoted from post at 16:03:39 10/12/22) Hydro lever wants to move too easily.. Going up hill it moves to slow the tractor, and going down hill it moves to speed the tractor. I know some is normal, speeding or slowing but you can see the lever move. Is there an adjustment? I see a 317 was adjustable. Holding the lever is a pain.
What is your tractor's serial number? DEERE used 3 or 4 versions of the hydro control lever setup, if you post your serial number I will post the exact details of the lever tension setup for your tractor.
