K 301 S update
buzzinduzzin
Location
se illinois
thanks again for the replies ! I ended up with Norm @ isavetractors.com & he had everything except the points cover & is working on making reproductions . Found NOS trigger modules & NOS volt/rect. but they are PRICY . Not sure if my charge sys. is 10 or 15 amps, but I picked out the one that looked like the old one in the Wheel Horse. The flywheel will not have to be changed to covert to points but I suspect that if for some strange reason someone wanted to convert from a points sys. to breakerless ign that you need a flywheel. Parts should arrive Sat. & will follow up to tell you all if everything works out.
ps the flywheel has the S & T stamped on it
