John Deere GX345 Mower
jd52ao
My Valve covers are leaking oil onto the exhaust when it sits. I want to replace the covers and gaskets( will use paper gaskets). I am not much for ordering stuff on line, but where is the best place to buy these items. There are Kawasaki dealers in the area. Comments??
The valve covers use a special shaped o-ring that sits in a groove in the cover. you won't be able to use a paper gasket. Just get the right stuff from a Deere Dealer, or any small engine shop should be able to get them for you from aftermarket sources such as Stens.
