briggs 20 v twin intek
fred kobs
Does anyone know the valve lash spec? 1 push rod is aluminum and the other isn't if it makes a
difference. Thank you in advance. Fred
.004-.006 both valves.
I usually use a .003 gauge, when you tighten the setscrew it gets to be a little more.
You can probably find a video online that will walk you through it, but not everyone that posts videos is a competent mechanic, bit I'm usually able to find a good one. If it has the centrifugal compression release that is so common now there is a specific crank location for measuring the clearance.
