330 Standard
I have a JD 345 lawn mower that I think has the Kawasaki FD611V or FD590V engine. I need to confirm. When it is running it will be running fine then all of the sudden start blowing thick white smoke then shortly quit smoking and run ok again. I have noticed it has started fouling plugs badly. I suspect piston rings like you would in a bigger engine but I have never seen one blow that much thick white smoke then suddenly clear up. It literally looks like the old mosquito fogger trucks when it does it. Also can it be rebuilt. I'm not seeming to be able to see a lot of sources for parts or overhaul kits for the 611 or 590 kawasaki engine on line.
