rderrick121
New User
Hello, my case 222 is not equipped with the hydraulic lift lever to the right of the steering column. Instead I have a vertical bar with a button on top to transport/mow with the deck that you manually pull back to you to transport or release forward to mow. Doing so really doesn't change much as far as the deck goes, the back still rides on the black plastic wheels and the front seems maybe only a half inch higher, does this sound right? I would like to get a plow for this tractor, is that a possibility with this style attachment lift?
Thank you
Thank you
