Cub Cadet 12 hp Engine
jb9959
My Kohler 301 is beginning to use oil. I would like to continue using the tractor until fall before overhauling the engine.
Any pros/cons about using 20-50 wt motor oil?
I run 20W-50 oil in just about every thing I have be it a lawn mower or a car or tractor so go ahead and run it, it will not hurt a thing
I don't think those engines are all that fussy.Any quality oil,whatever flavor you prefer.I have one in a 73 that has had nothing but 15-40 Rotella T in it since new.That engine started to use a little oil about 4 years ago.We have no clue how many hours are on it,but it has never had the head off.It has had either 3 or 4 carbs,the throttle shaft wears the aluminum body away,and a couple of fuel pumps.The tractor has worn through 3 or 4 mower decks shells also_Oil is cheap,unless it has been run out of oil I think I would keep using it.
Might be better to switch to straight 30wt. oil. No thickness variations through heat range. Give it a try.
I'd use 30 in it. I like those old Kohlers, got a 14 horse that had a new short block in the early 80s, must have a million hours on it now, seems to rattle a little more but won't use a drop of oil. It's semi retired to tiller duty now.
Quick lesson on Multi viscosity oils. In case you do not know..
Take a 10W30 for example.
10W = Viscosity of the oil in cold weather.
30 = Viscosity of the oil at operating temp.
So a 10W30 oil is the same as straight 30 weight when hot. But the 10W offers far better flow and protection when cold starting and during warm up.
straight 30 non-detergent is the only oil I would recommend, none of these modern synthetic and detergent oils were even available when that engine was built.
I would just keep using the oil you have been using. Half a pint of oil use per tank of gas is not really that bad. Just ALWAYS remember to add oil between tanks of gas.
