Texasmark1
Still chasing a soft rides so current task is removing the 13x5x6" fronts on my Ferris IS700z and replacing with 15x6x6s. Getting tires on 6 and 8" rims are usually difficult but this rim was only 4.5" wide and that added to the hassle. As you all have experienced I'm sure, the assembly won't sit still and you play chase the bar around the wheel as you try to get the tire mounted, especially on new, freshly painted wheels.
I made an adapter for small tires to fit my regular hard mounted tire changer but the mounting stud is ?" and this wheel has a ?" axle opening. I tried putting it in my 6" vise but wound up wrestling it on the floor.
Initial mounting the first side with soapy water, was just a matter of pushing it on. The other side as usual was the problem.
The lip on the rim was such that it accepted vise grips...one of those improved seal types with a little extra rim sticking out beyond the tire bead. One pair locked the starting point and the other pair followed the screwdriver around the side as it made some headway I followed with the grips so I didn't loose progress made on that end. This way the locking point didn't follow you around the wheel and nullify any progress you thought you were making. Working dry worked better than wet on this side and in short order the tire was on the rim.
Thought you might find this helpful the next time you challenge those little boogers.
