David bradley sickle mower
Are you talking about the Knife sections? Those triangle shape things with two rivit holes and very sharp edges. You can find tons of stuff on Ebay but you need to measure everything on your sections. Thinkness, hole placement, top or bottom edge, length, etc. There is a company on the net that specializes on sickle mowers. Somebody will post the name. When you get it set up correctly it is amazing how well they cut. They are ment to cut Grass, not Saplings or wire!!!!
The originals are part number for the knives..
[b:0cab11d74a]David Bradley 4565M[/b:0cab11d74a]
If you can find them with the rivets do not curse me for letting you know up front that you can expect to pay around $350 - $450 for a new factory OEM set .
CAN NOT SAY if they will fit or not, but... You can find new Troy-Bilt - Trailblazer Sickle Mower knives for around $100 for a of set (8 knives and rivets). The Bradley uses 17 knives if I am not mistaken.
