fender assembly for Kubota G6200
appraiser
Cracked the fiberglass fender assembly. Anyone know of a good parts yard? Kubota has discontinued and does not have any. Anybody had any success taking this to a body shop for repair?
Almost impossible to find around here. But,easy to fix. Any body shop that can work on a Corvette can fix. Or, just grind a shallow vee on both sides and lay some glass cloth saturated with resin on it. Then roughen that and finish with body filler. All the stuff to do that should be available at Walmart.
Agree with Ken. If you take it to a Corvette boby shop it will cost a few bucks, but the repair should be done correctly. Take a rattle can of the correct Kubota color with you so they can complete the job. Kabota has two or maybe three orange colors by now.
Thanks guys. I have called all over the U.S. and can't find one. They must not have made many. I will check out a body shop.
