Case J46 deck
CKain(MI)
Any tips on removing a stuck deck pulley. The one under the drive pulley. It's not strong enough to pull with a 'puller', with out serious bending it. I suppose the main answer is, heat, heat ??
drill a couple of holes as close to the hub as possible. Use them with a couple of bolts and nuts to connect a puller. Then: Heat heat heat
OK, I got the pulley and shaft assy removed. NOW looking for used parts ???
drive pulley (15615), center spindle(15604)....
