Jack in Michigan
I picked up a John Deere 332 with the 3TN66UJ 3 cylinder Yanmar Diesel engine, but I can't get it started (I bought it that way). I have fuel to the injectors and the glow plugs are working, so I suspect that
I either have bad injectors or I am going to find low compression readings; however, my current compression tester does not have the correct fitting to screw into the injector hole. I need to find out what
size the threads are that go into the block where the injector screws into or if someone has some other suggestions I would surely appreciate it. There are 1,140 hours on the machine.
Thanks,
Jack
Thanks,
Jack
