TractorLinks.com
JD 1992 420 issue
Hobbes116
06-13-2018 19:01:51
This is my first post here so sorry if this is missed placed or too long.
So I'm mowing (story form for added entertainment value) and, I end up mowing up a 6ft by 3 foot carpet hallway (I was on grass lawn not in a hallway). That carpet grabbed onto the center spindle and stopped the blades. I turned off the pto because of resulting sound. Removed the item hit on the pto and recieved an unfriendly sound and blades made a 1/4 turn . Moved into the garage, removed the pto drive shaft and pto seems fine. Removed the deck. The spindles are all fine. The gear box manually turned will spin the blades but with added resistance tho. So I. The roll pin looks odd like it might have broken in two. I'm looking at the gear box. What do you think I'm looking at?
Hobbes116
06-17-2018 13:21:23
 Re: JD 1992 420 issue in reply to Hobbes116, 06-13-2018 19:01:51
Ended up waiting till next weekend, read up and yes I'm hoping the half moon shears are the key as they are not made of harded steel unlike the stafts.
DoubleO7
06-16-2018 11:40:51
I would bet either gear is trashed (or both) or one of half moon keys sheared.
Mule Meat
06-15-2018 18:04:49
Would your mower be one with a timed deck?
Just asking..
Hobbes116
06-14-2018 09:47:50
That might have to wait till the weekend, but I think I'm headed that direction. Pricing on a replacement gear box is about as bad as the pto itself. So after reading some of the rebuilding posts, I'd rather spend the $30 and do the rebuild verses the 800 to 900 for a new one. Man I hope it's just a shear pin.
Hobbes116
06-14-2018 09:43:38
I will give that a go and send a pic.
Bob
06-14-2018 09:50:10
 Re: JD 1992 420 issue in reply to Hobbes116, 06-14-2018 09:43:38
You can look up parts drawings for your mower at http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt.
Here's the parts breakdown for the Peerless gearbox:
Hobbes116
06-14-2018 09:42:44
Yes the pto has been run with the deck disconnected and all seems well, sounds and looks good.
My thoughts good to shear pins on outboard motors. I'm just not sure if there is one and where to find it on the peerless gearbox. I'll send pics tonight after work. Thank all for the reply to my initial post.
DoubleO7
06-14-2018 07:49:33
With nothing hooked up downstream of the deck drive pto, does the pto function on and off like normal?
DoubleO7
06-14-2018 07:46:40
Can you put a wrench or vise grip up and down stream of that odd roll pin and try to turn them?
Maybe that roll pin is the overload shear pin.
I would first confirm the pin is whole before tearing into it deeper.
I would research for an exploded view of the deck drive system and look at the parts involved. Might also be one or more shaft keys and maybe one of those sheared.
Bob
06-13-2018 20:51:00
NOT sure what you've got going on, but (obviously) you've got to take the cover off of the gearbox and have a look inside, IMHO.
