That middle zerk on the 54" deck is very hard to reach with the rubber hosed grease gun. I am going to try to replace that zerk with a 90 deg. one. Testing one of the outer spindle zerks to see if it unscrews (using a vise grip) seemed like it was very tight and I did not want to wreck the thing...are these zerk fittings pressed in?
Worst case, I will have to drop the deck off and pull it out from under the tractor...seems like a lot of work!
Thanks for your knowledge...Leo
