TractorLinks.com
GT235 poor design for tie rod
Greenfrog
06-10-2018 20:52:37
I like this lawn tractor, however the tie rod that goes fron front tire to front tire fell apart. The rod end wore out and ball came out of socket. The problem is that the socket is IN the end of the rod. There is no replaceable rod end. I have to buy a whole new tie rodó cost 28$...!!
The drag link does have a replaceable rod end. Any suggestions here on repair rather than replacement?
I am thinking about using a 7/16 rod, cut threads on each end, and use ball and socket rod ends like those on my old CubCadet. Or, even using Heim joints. The rod does bend on each end.
Mule Meat
06-15-2018 17:59:54
 Re: GT235 poor design for tie rod in reply to Greenfrog, 06-10-2018 20:52:37
7/16"?? Most likely would be cold rolled steel. You start putting bends in it and it will not hold up to long on a mower.
1/2" ID .125 dom bent with threaded inserts for male threaded tie rods would be a better investment.
Found out one thing about Home Depot John Deeres...
All you need to replace the deck hangers is a couple of ole metal coat hangers..
Russ from MN
06-15-2018 10:45:05
I have fixed those by splitting a flat washer and welding it to the socket, with the ball contained. Shoot some grease into it and it will last a long time.
wgm
06-11-2018 07:59:17
There aren't many OEM parts that cost $28.00 or less. Need to pry open your wallet. Monkeying around trying to cobble something together ain't worth it sometimes.
Greenfrog
06-11-2018 16:40:48
 Re: GT235 poor design for tie rod in reply to wgm, 06-11-2018 07:59:17
Yup. You are right. I just thot I would throw the idea out there.
Duner Wi
06-11-2018 06:28:42
I think your drag link has 2 replaceable ends. Couldn't you take 2 ends like that and weld them onto your tie rod. I have JD111 and my drag link only has one replaceable end so when mine fell apart I purchased the replaceable end and welded it to the other end of drag link. I also drill a small hole so I can grease the joint with my chain saw bar grease gun. I have also found that not all ends are the same hardness. For $28.00 for the assembly I might be tempted to buy the assembly and move on to the next battle.
Greenfrog
06-11-2018 16:41:38
 Re: GT235 poor design for tie rod in reply to Duner Wi, 06-11-2018 06:28:42
Good idea. Thx
Bob
06-10-2018 23:58:52
So, how many years/hours did you get out of your "consumer grade" lawn mower 'til this happened?
For $28 you can't save a lot by fabbing up an "improved version" from new parts, IMHO.
Sometimes, you just gotta "pay the piper" and move on.
(Disclaimer) Of course, I'd probably dip into my used parts inventory (AKA, junk pile) and waste some time making the problem go away! (YAMMV!)
Greenfrog
06-10-2018 20:58:31
I just checked, It is 38$ on Amazon! Is 28$ at dealer. Imagine that! ☹️
