bigbob1939
As you suggested I got a spark tester. Spark is good when it stalls. It has the little diaphragm pump that is hooked to the valve cover to operate. It was mounted above fuel level, I moved it to below fuel level, no change. I put a vacuum gauge on the connection of the valve cover with motor running it just pulls a vacuum, keeps going up longer motor runs to @ 3 psig. I thought it should change from vacuum to preasure with each stroke of the piston. Am I right? Is this the problem? Thanks to anyone that can help me out. I will be needing to trade my dog for a goat soon if mower doesn't get going.
