TractorLinks.com
Mower deck bearings
Ih10020
05-16-2018 16:11:54
Have a cub cadet with 48 inch deck,the drive spindle is bad,can the bearings be replaced or just order a new spindle? Thanks in advance!
Texasmark1
05-17-2018 05:08:24
 Re: Mower deck bearings in reply to Ih10020, 05-16-2018 16:11:54
I thought I'd replace the bearings on one of mine till I realized that the aluminum spindle housing was wallowed out where the bearing siezed. I just (a couple of weeks ago) bought 2 replacement new spindles with OEM quality belt and 2 sheaves, free shipping off ebay for about $75. You can get the same thing with 2 new blades and free shipping for under $100....Husqvarna 20TK46 twin blade....I already had 3 sets of blades. Shipping was fast. Got it installed and works great.
Mule Meat
05-16-2018 19:17:52
I am thinking that the 48" deck on the 2185 was a Cub Cadet 301.
If so, Yes you can buy just the cone bearing Cub Cadet part #941-04298. They only cost about $10 each and each spindle uses two of them except for the double drive pulley (engine to deck, deck to blades) Those are ball bearings Cub Cadet #741-1122 and cost around $20 each and you need two of them.
jeffcat
05-16-2018 18:40:23
The older decks have a little metal tag on them with the information.
Ih10020
05-16-2018 18:11:52
48 inch deck on series 2000 2185 cub cadet.
nophun
05-16-2018 18:58:16
 Re: Mower deck bearings in reply to Ih10020, 05-16-2018 18:11:52
You can replace the bearings as long as the spindle housing isn't cracked, these are $$ if you have to replace the whole spindle.
They use tapered roller bearing with race, I've never had to actually replace bearings but I'd assume they are a common size; you'll have to get one out to get the numbers off it to see.
Butch(oh)
05-16-2018 17:53:45
Some yes, some no. Depends on which deck, they built a lot of different 48" decks over a very log span of time. More information needed.
