TractorLinks.com
O/T Manual for the engone on my Cub Cadet Wheeled Trimmer
wsmm
05-11-2018 16:55:42
Bought a new Cub Cadet wheeled trimmer, the manual that came with it for the engine is an MTD engine manual. Ut is a 195cc OHV motor. For spark plug replacement info they only givre you the MTD part number. Their is a charcol canister filter that you may or maynot have to replace depending on how dirty it gets, but no part number given. Also no information on what the lash setting is for he valves. Called MTD they were no help sbasically sid most people din't wnat to be bothered to set valve lash so he didn't have any specs. So if any one can supply the missing info I would greatly appreciate it.
Rodney51Cub
05-12-2018 12:47:14
 Re: O/T Manual for the engone on my Cub Cadet Wheeled Trimme in reply to wsmm, 05-11-2018 16:55:42
According to my info for a 5X65VUA engine, it is 159 CC's.
The valve adjustment is the same as the 195 cc. The plug is a Torch F5RTC or NGK BPR5ES.
We do not get many push mowers or walk behind trimmers where I work so I am just going by the Cub Cadet Web site.
Part number for the canister filter, 951-14400. According to the parts diagram it is a removable filter, but the service manual has you changing the canister assembly, 951-14629.
Hope this helps
Rodney 8)
Rodney51Cub
05-11-2018 20:21:07
According to the service manual it is a EPA tier III requirement. It is just how the manufacturer deals with gas vapors out of the tank. Some use a carbon canister and some use a special fuel cap.
Rodney 8)
Rodney51Cub
05-11-2018 20:00:25
The 195 cc OHV motor valves are set to .004 - .006 intake and .006 - .008 exhaust. They use a Torch brand spark plug F6RTC that crosses to a NGK BPR6ES, set to .024 - .031. Need more numbers off the engine to find part number for carbon canister.
Rodney 8)
wsmm
05-12-2018 07:16:17
 Re: O/T Manual for the engone on my Cub Cadet Wheeled Trimme in reply to Rodney51Cub, 05-11-2018 20:00:25
Additional Iformation on the engine on the Cub Cadet Trimmer
Model # 5X65VUA Serial # 1710131A1103
jeffcat
05-11-2018 20:09:39
Hey Rodney, Those NGK plugs are great. Got a question. That canister deal is a California gas vapor thing? Glad the rest of us don't have them. Just curious.
