jr1983
Anybody know of a reasonable replacement for a 4-
12 ag tire? I'm having problems locating one. I have
ATV tires on my simplicity model L. It works but it
moves way to fast.
If you have 12 inch rims on a Gravely L it would have to have the optional gear reduction hubs installed as the regular rim size is 8 inch with a 16 inch overall diameter tire. But, if you have the reduction gears I'm surprised you find it moves too fast unless your current tires are really tall. What size tires do you have now? By chance has your L been retrofited with larger wheels but without the reduction gears?
The basic L was the fastest-moving version of that tractor. The LS ran at half the speed and the LI was midway in between the two. The only difference between the three versions is the gear set that drives the axle and these parts can be interchanged.
