Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Adjusting Cub Cadet Snowthrower
Josh M.
01-13-2018 10:18:14
I need to adjust a Cub Cadet QA42A to fit my narrow frame Cub Cadet 125, it is set up for a wide frame. What are all of the things I need to move to set it up for a narrow frame Cub?
R Bedell
01-17-2018 03:57:40
 Re: Adjusting Cub Cadet Snowthrower in reply to Josh M., 01-13-2018 10:18:14
Josh M:
There is NO need to cut, weld, or add anything.
Go here, and download the Operator's Manual.... http://www.ccmanuals.info/throwers.html
You will the QA42A on Left hand side at the bottom.
DoubleO7
01-16-2018 19:47:03
There is no need to cut anything nor weld anything or add anything.
When you see it you will be able to see how it can be adjusted to fit either a WF or NF Cub Cadet.
traper
01-13-2018 10:57:34
josh the easy way is to cut side rails just below frame narrow by welding a 1x1 angel iron at correct width.Any other way is a pain traper
