Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
spindle speed?
JL Ray
01-03-2018 09:41:24
Does some one know right off what the spindle speed is on a mower deck with 20 inch long blades?
JL Ray
01-04-2018 17:41:09
 Re: spindle speed? in reply to JL Ray, 01-03-2018 09:41:24
i think with all this info I can run the deck straight off the hyd motor I have. I just need to find the right pump now. I think I already have it, I just need to locate it. The rest is just labor.
Doug - Iowa
01-04-2018 15:44:27
A 20" push mower runs direct off a 3600 RPM engine, so I'd plan for that.
JL Ray
01-03-2018 19:06:11
jim: where are you located?
Jim in rush co
01-03-2018 19:47:02
 Re: spindle speed? in reply to JL Ray, 01-03-2018 19:06:11
40 miles southeast of Indy. I would like to see a few more of the ditch bank mowers and steal a few more ideas. MF dealer had one couple yrs. ago and has me thinking I could come up and make one. It had pto pump and a large oil tank on apposing side of the arm and deck
JL Ray
01-03-2018 18:23:00
It may be a bit. This is a do it as I have time and find parts project. I have motors. Need to find a pump which I think I have. Just need to look. I have the deck. Have meterals for the frame work. Have the lift cylinder. Have the valves. And not in a hurry.
JL Ray
01-03-2018 16:26:07
I have a pair of Super 55 olivers. I'm going to mount an arm to the side of one which has a loader frame on it. Approx 10 to 8 feet out from the tire. On it I'm wanting to mount a 60 inch JD deck. I plan on making the deck movable so I can have to horizontal or vertical. So I can mowe pond and stream banks or trail sides to keep them open and brush off my truck.
Basically make a mower like the county hires to do roadsides but mines on the cheap.
54 acres mostly wooded. Two ponds and a stream going thru the property. My little heaven.
Jim in rush co
01-03-2018 16:54:53
 Re: spindle speed? in reply to JL Ray, 01-03-2018 16:26:07
I wandered if that's what you were doing. My Allis deck will be Ok for mowing the side ditch, I was going to mount off to side also but I have a lot of field edges with woods and sure would like to have something that would cut maybe 1-2" stuff and put on JD tractor but probably would need pto pump to get enough flow. I have email open when you get it done shoot me a picture.
Jim in rush co
01-03-2018 15:29:20
JL, just curious what you might be working on? I have been thinking about mounting an Allis deck on front end loader and driving it with hydraulic motor. I have 1/4 mile of ditch along state highway and thinking of something I can mow it with from my side only, them people are nuts out there!
Mule Meat
01-03-2018 12:21:23
Spindle speed can be determined using simple math.
First get the engines max operating speed - RPM.
Measure the drive (engine) pulley diameter.
Measure the driven (spindle) pulley diameter.
Now an example if the drive pulley is smaller than the driven pulley.
Engine speed = 3600 rpm.
Drive pulley = 6".
Driven pulley = 7"
7 divided by 6 = 1.16
1.16 divided by 3600 = 3103 rpm spindle speed when the engine is running at max rpm.
Now if the drive pulley is larger than the driven pulley.
3600 rpm engine speed
8" drive pulley (engine)
4" driven pulley (spindle)
8 divided by 4 = 2 (2.0 -1)
Now you multiply the engine speed by the results.
3600 x 2 = 7200 rpm
jl ray
01-03-2018 12:59:52
 Re: spindle speed? in reply to Mule Meat, 01-03-2018 12:21:23
I don't have all the pulleys in between. I have a mower deck and a hydraulic motor which turns 3000 RPM. I was wanting to know so I could make the connections to get the correct rpm.
JL Ray
01-03-2018 12:15:44
Yes thank you. That is what i was looking for.
Jim in rush co
01-03-2018 11:51:26
My Kubota 60" cut. Blade length 20.6" Blade tip speed 14,271. Spindle speed 2647 RPM. hope this helps, Jim
