TractorLinks.com
John Deere 755 front blade
jack345
11-26-2017 09:21:40
I'm looking for a front snow plow for JD 755,855 or 955 tractor built in 80's-90's. I know JD made the 380 blade for the 55 series and are hard to find. Did anyone made a aftermarket blade for this tractor or will some other like JD 450 series fit ? Thanks
Mike M
11-27-2017 12:25:42
 Re: John Deere 755 front blade in reply to jack345, 11-26-2017 09:21:40
I took an old Meyers snow blade from a truck and cut it down and made the brackets to mount it on our model 750. Wasn't too hard to do. I know finding used implements to fit discontinued tractor models is really hard to do. And even if you do find the right implement JD made so many different style of brackets too. You don't always get the brackets or the proper brackets.
jack345
11-27-2017 14:11:17
 Re: John Deere 755 front blade in reply to Mike M, 11-27-2017 12:25:42
Am thinking about doing just that, were you able to use hyd up/down & angel ?
Mike M
12-01-2017 12:58:42
 Re: John Deere 755 front blade in reply to jack345, 11-27-2017 14:11:17
Yes. For the angle the original cylinders were used. I bought a small 2 way hyd. cyl. from surplus center and made a bracket to attach it to the front weight bracket to use for the lift.
farmerjohninpa
11-26-2017 19:03:46
there is a few on craigslist in des moines ,,even has a 4' box blade for $700.. do not know where you are but check local states near you
jack345
11-26-2017 20:16:30
 Re: John Deere 755 front blade in reply to farmerjohninpa, 11-26-2017 19:03:46
Yeah, I've been following CL but nothing shows up in the Northwest US, that's why I was hoping to have more choices from other models for blades
