I need to adjust the gap between my new flywheel and the coil. Is it even correct to call it a coil? This engine does not appear to have any type of points, so I am assuming what I am adjusting is an electronic ignition? My problem is the two Philips head screws are not budging. I am trying my best to not round over the slots. I have sprayed them with PB Blaster, and used a little heat on them. They still do not want to move. Any suggestions to loosen then up? I am also assuming these are slotted holes which will allow me to get my .020. Is this correct?
Thanks.
Thanks.
