Looks like my attempt at repacking this was a success.
I have a JD F725 lift cyl. but others models use similar made cylinders welded together and not meant to be rebuilt.
I cut the barrel end off in a lathe and was then able to take it apart and matched up seals at a local shop. Put it all together and had a good welder weld it back together. Hooked it up and tested it and so far it looks like it worked ! I have a lot less in it then the about $ 400.00 JD wanted for one !
