Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Harbor freight Predator 212 engine
Greenfrog
10-28-2017 18:01:48
I need to switch a blown engine on a Toro front tine tiller. I am considering the HF Predator 212cc The bolt holes line up, the shaft is even the same size-- can even use the same pulley.
Was a 5hp Briggs on it; predator is 6.5hp (good!)
Question: has anyone out there ever tried one of the engines? On sale right now for 94$. usually 119$
Thx in advance on any input discussion on this.
wjpinks1
11-24-2017 06:59:32
 Re: Harbor freight Predator 212 engine in reply to Greenfrog, 10-28-2017 18:01:48
I put a Predator engine from Harbor Freight on my gas powered air compressor a few months ago and it's been an excellent engine. Starts very easily, runs great, and does its job as well as a Honda, Kohler, or Briggs that cost several times more.
ztr mowers
11-17-2017 14:41:07
would not be afraid to use one for that at all
ACSam
11-17-2017 07:30:13
I was sceptical of these engines at first. After doing some due dilegence on parts availability, I put a 212 engine on a yard vac this summer. Started on the second pull. Haven't had any trouble at all. As far as replacement parts, google "predator engine parts". very good availability.
Texasmark1
11-14-2017 05:41:33
Was using one of mine yesterday and realized that it also contains a fuel shutoff valve (so that you can run your carbs dry when seldom used) that my BS engines don't. More of the Oriental mind-set. Diversity is good!
47fivewindow
11-05-2017 16:39:03
They say they are the same as a Honda. With the Honda on my Snapper tiller the exhaust now blows out the front. Huge improvement over the Briggs out the side.
4520bw
11-01-2017 09:08:13
I replaced the 5hp Briggs and scrapiron on dad's tiller with the 6.5 and never had a problem.
Bret4207
11-01-2017 05:29:20
Depends on whether the sensor completes a circuit or breaks it.
Texasmark1
11-01-2017 15:48:06
 Re: Harbor freight Predator 212 engine in reply to Bret4207, 11-01-2017 05:29:20
Since we are talking about small engines here I'd think that in today's environment they are all solid state magnetos...aka a laminated soft iron core with a lot of varnished (insulated) wires wrapped around it that a magnet passes by once per rev, one per cylinder, generating an energy pulse. The tap on it is used for ignition kill when you turn the ignition switch off. Any safety switch is wired to ground so that when activated it puts ground on that terminal. Shorting as few as 1 turn on a transformer can render it inop. for all practical purposes due to the physics of the device.
Bret4207
10-31-2017 05:23:50
Well, considering the number of retards out there that never think to check their oil, it's not really a bad idea at all considering HF has a pretty generous return policy.
hd6gtom
10-30-2017 19:14:27
Wondering what is wrong with running them on a tiller? Have seen several with them on it. Seemed to be OK.
Ivan in Mich
10-30-2017 18:57:34
I put a 6.5 hp on a tiller last spring and so far it works very good. Easiest starting engine I have ever had. My son has the bigger one I think it is 20 hp plus and it is 2 or 3 year old . no problems with it
Greenfrog
10-30-2017 18:56:45
More info on my own question:
I learned that this engine has a low oil sensor that shuts the engine down. Good idea. NOT!
After reading reviews on it, this is not suitable engine for a tiller. That is, if the engine tilts too much, as can be with a tiller such as when digging deep, or tipping down to pull/ drag it backwards, since here I will have llost the reverse feature that the old machine had, this engine will shut down. I decided not to use this engine.
RayP(MI)
10-31-2017 16:36:19
 Re: Harbor freight Predator 212 engine in reply to Greenfrog, 10-30-2017 18:56:45
Cut the wire to the oil sensor?
Texasmark1
10-31-2017 04:38:06
You can always remove the wire from the sensor. However, most sumps are made for 30 degrees of tilt and still supply oil, including splash lubed engines. Personally I wouldn't give it a second thought on that engine or any with the feature.
Texasmark1
10-29-2017 05:09:39
I have 2 and they are very well build and the design is well thought out. I have lots of BS engines too and I like them but there are other good engines out there for sale.
504
10-28-2017 19:05:28
The only trouble I have heard of, was bad spark plugs,they must have had a bad batch about 4 years ago.
wgm
11-03-2017 09:36:06
 Re: Harbor freight Predator 212 engine in reply to 504, 10-28-2017 19:05:28
Must have been using Champion spark plugs.
jeffcat
10-29-2017 08:55:18
I had the same thing happen with my little 800 watt utility portable generator. The thing refused to fire. Pulled the plug and it would spark. Screw it back in and no soap. Went and purchased an NGK plug. Magic, it runs perfectly.
t.r.k.
10-28-2017 18:17:50
I put one on a Troybilt Horse for someone several years ago. It seemed to work o.k. and I never have seen it in our shop since.
That said, I don't know of any local parts support for those engines. I got a part for a Harbor Freight drill press once, dialed the 800 number and talked to someone overseas who had a lot of trouble with the English language. I consider it a miracle that I got the part I needed and it was actually delivered to my house.
Don B.
10-29-2017 08:53:02
 Re: Harbor freight Predator 212 engine in reply to t.r.k., 10-28-2017 18:17:50
would not use a Predator on anything even if free. Future parts availability, not being American made, just the start of why I am not a fan of them.
juicybusa2
11-01-2017 19:02:09
 Re: Harbor freight Predator 212 engine in reply to Don B., 10-29-2017 08:53:02
Have had one as a replacement engine on a rear tine tiller and it has been flawless for at least 5 years. As for parts, if u do happen to need, the engines are a Honda clone and parts are a direct fit.
