Was wondering if you could give me some advice on a wiring issue I am having with a K161.? We saved this engine from the scrap heap and got it running again, which is a feat in itself.? The engine is in an 1950s vintage garden tractor with a 6 volt positive ground system.? Everything works as it should, however, I am not certain if the generator is charging the battery, as the am meter is not moving, either positive or negative, as the tractor runs.
I have attached a schematic of how it is currently wired and was hoping you could take a look and see if it looks right?? I watched some videos on wiring a tractor, but the ones I could find showed wiring using a keyed switch and solenoid.? My tractor has neither it has a heavy duty push button starter switch and single pull ignition switch with only two leads on the back.
