Parts for Massey Ferguson 1655
Overnite
Hello all, I just acquired a Massey Ferguson 1655 garden tractor that is currently not running. I know nothing about Massey Fergusons or where to get parts. I was hoping someone could point me in the right direction for new or used engine parts, chassis parts and possibly a place to get a FEL or front blade for it. Thank you for any help, Bryan.
Hi Bryan
Some parts will still be available from Agco. Others may not....
Let me know the part numbers you may need and I can possibly find them. Part numbers are available on the "Agco parts books" site.
Wayne
Isn't the Massey Ferguson 1655 and the Snapper 1855 nearly identical tractors?
The MF 1655 was built by Snapper and production of the 1655 ceased in 1979 when Snapper introduced the 1855.
Get your Onan parts from Boomers Influence. Forget Agco or anyone else mentioned here.
http://boomersonanparts.com/
Thank you everyone for your input. I need an ignition switch because the one that's on it does not have a key. It has 5 prongs on
the back of the switch but the only number is a patent number. I will try to get into it deeper this weekend. I would like to get
the fuel tank cleaned out, change oil and put in a new set of plugs and see if it will run so an ignition switch would be
helpful.Thanks again everyone for your help. I just can't help myself when it comes to tinkering with thing like this.
If you need a key switch. Look for...
Snapper part # [b:dac2b90fdf]7019543YP[/b:dac2b90fdf] (newer part number)
Snapper part # [b:dac2b90fdf]7019543[/b:dac2b90fdf] (OEM part number and will most likely come up "unavailable" at most places).
Thanks again everyone for your information. The tag on the engine shows BF-MS 3221E. I am in need of part #537 115 M91 "adapter
assembly, engine" and the splined coupler for it and the "pulley assembly drive" part"#3 21 333 M91. New parts are probably not
available so if anyone may have used to sell please let me know. I also need the 2 belts part #3021 289 M91 if anyone has a cross
reference number?
