Hdonly
- Location
- Florida Panhandle
I just bought a Craftsman LT1000 with B&S 19.5 hp mower for $50. From the seller's account of what happened, I thought that it sounded like a fuel pump leaking gas into the oil. Easy fix that I have had good luck with before. Well, not this time. After checking the oil, there was none. Took the chance and put fresh oil in and got the engine to start. It made some funny noises and then settled into a nice smooth idle. Thought I had it made. Then it made some really sharp clangs and bangs, and started idling smooth again. Then is started getting slower and slower till it just stopped. Locked up tight. I found a rod bolt and two pieces of a piston skirt laying on the frame outside the engine. Then I found the hole on the backside of the access cover. Not good at all.
My question now is this. I have an older 19.5hp B&S motor in another Craftsman mower that the deck is worn out and the transmission is shot. I would like to know if anyone thinks this engine would swap out. The newer mower has the automatic transmission in it and the deck is in really good shape. A quick look at the engines appears that they are close to identical, although the numbers I have for the older one says it is obsolete. Both are the opposed twin cylinder flathead engines.
