Jim Dandy value??
Tom R.S.
Don't need another tractor but I'm intrigued by this one.
It has a 12 HP Wisconsin, a 4' wide snowblower, original lights and sheet metal,Economy cab made of flex plastic and a hard white plastic top, wheel weights, fair tires appear to be original all holding air.
Its oily and grimey but not rusted. definitely a work tractor and never restored.
Runs.
There asking 950 but they were almost begging me to make an offer.
Hi Tom what model year is it if you don't post some pictures of it and the SN, are you sure it has a Wisconsin engine they did use wis, engine but I don't think it was ever a 12hp engine they did have 12 HP Kohler engines, does it have a starter / generator or a gear type starter? Is there a mower deck with it, does it have hydraulic or manual lift ?
GB in MN
GB
Now that I look at this it does look like a Kohler motor.
It looked like it had some hydraulics because there was a lever on the "dash" that said up and down.
Here's a photo.
I had a 1958 Economy that had a 10 horse B&S that was original and it had hydraulics. No implements, sold it last April for $ 800. Always started, never failed or gave me problems. Wish I would have kept it. Hoever, it went to a young man 16 YO who fell in love with it.
s
Hi Tom the photo didn't make it, the Kohler most likely is a K301 12hp without seeing a pic my guess is $950 may not be to far off the 48" snowblower is worth $300/400 the cab is $250 / 350 the wheel wts are $50 to 100 so that leaves the tractor pretty reasonable only thing it a 12hp is going to have a full time job with a 48" blower try the photo agin
GB in MN
Let's try this photo again.
Hi Tom that's a Power King not a Jim Dandy JD's had 8" front wheels/tires, its what is referred to as a short hood Economy/Pk it just may have a 14 hp Kohler K321 (that would have been the original engine) its a somewhere in the 1960's hard to tell with the cab on but I think early 60's. Good luck on your dealings
GB in MN
