TractorLinks.com
Craftsman 20/46 deck height
Gary Mitchell
09-03-2017 09:07:05
We have a Craftsman 20/46 gold colored riding mower that's about 10 years old. It seems like when we first got it I mowed with the deck height setting at 3 or 4. Over time that has come up to mowing at level setting 5. 4 almost cuts it at the ground. I looked under the unit and at the deck. I don't see any way to set it up any higher than it is. What am I missing? gm
ztrmowers
09-03-2017 15:52:08
 Re: Craftsman 20/46 deck height in reply to Gary Mitchell, 09-03-2017 09:07:05
the deck hangers have adjustment, you need to look again
t.r.k.
09-03-2017 12:17:06
When was the last time you put air in the tires? Set the rears at 15 and the fronts at about 20.
Mule Meat
09-03-2017 10:08:48
I will tell you a good one on Craftsman deck adjustments..
A Sears "tech" came to a guys house three times to hack on the deck of his mower that would only raise to about 3" at the highest setting. The third trip Sears answer to gaining deck height on a 6 month old mower.
Spend another $300 dollars on bigger tires.. :shock:
Gary Mitchell
09-03-2017 12:52:20
 Re: Craftsman 20/46 deck height in reply to Mule Meat, 09-03-2017 10:08:48
I always air the tires to firm before I mow. I'm considering taller tires if I ever replace these. What befuddled me is it used to run higher thAn it does now. I suppose between some tire wear and old age sagging lies the answer.
IA Roy
09-05-2017 13:10:16
 Re: Craftsman 20/46 deck height in reply to Gary Mitchell, 09-03-2017 12:52:20
Check linkage holes for wear out of round. Maybe need to drill out and put larger pins in to tighten up.
