Duane Klinger
New User
I got a JD 116 with a charging problem to repair. My question is , does anyone know the correct stator to use on this unit? It has a dual circuit stator with a red and black wire coming from the stator , red wire has the diode installed in it but the jd service manual calls for the single red wire style and then they run it thru a diode modual to convert ac to dc which is not in the wireing harness of this tractor.Could there have been a serial number break at some time that the system was changed ? One more thing every dual wire stator I've tried so far is grounded to the unit and creates a load draw on battery to deaden it when I hook the wire to the positive post of the battery to charge it . Any help would be greatly appreciated !
