craftsman reverse blade shutoff
MI-Bill
Craftsman 3000 42" deck about 5 years old. I would like to bypass the mower deck shut off feature when putting the mower in reverse. I mow a small yard where i have to put the mower in reverse often. wiring diagram is confusing. does the switch on the shift disconnect the positive or the negative side?
My 3600 has it built into the iginition switch. The key has to be in the center position and you can cut in reverse.
