So I tried disconnecting the mag shut down wire and the thing would not spin over at all. Messed with ti and tried to figure out how the heck it is wired up and nothing I tried has worked. Now if will not even start so thinking some how I have burned out the mags. This thing is nightmare when it comes to the way it is wired up and all the safety stuff.
Seat safety does not work right and if your sitting on the seat it will not spin over.
Brake safety does not work and if your pushing don on the pedal it will not spin over.
If you do get it started if you try to turn on the PTO the engine dies.
If your on the seat and you try to turn on the PTO it does nothing at all as in keeps running but the PTO does not engage.
