simplicity 40 40 tractor
Are you asking about the Simplicity 4040 power max if so your best place to check would be on the Simple tractors forum just google simple tractors
GB in MN
(quoted from post at 10:05:40 07/14/17) Are you asking about the Simplicity 4040 power max if so your best place to check would be on the Simple tractors forum just google simple tractors
GB in MN
Sorry, I did not give more info. It is a simpicity 40 40
Has two I.D. no 705 00185 patrs
I.D. no 001215 on chasis
ONAN motor: model no CCKA-MS/ SPEC. 2026G
serial no 0671307482
I have tried for several days for the year of this tracor and year and HP of the motor with no sucess. Every time i type this info in it comes back no info found.
Thank you very much for any info
Neal Harvey
GB in MN
Neal Harvey
http://www. jensales. com/products/simplicity-lawn-garden-tractor-onan-engine-service-manual. html
http://www. jensales. com/products/simplicity-lawn-garden-tractor-service-manual-sim-s-4040. html
Since this place will not let you edit your post...
Copy and paste.
Remove the spaces between the [b:ab58ac7061].[/b:ab58ac7061] and [b:ab58ac7061]Jensales[/b:ab58ac7061] and [b:ab58ac7061].html[/b:ab58ac7061]
(quoted from post at 09:58:37 07/15/17) checked these out, no info on my tractor.
Thank You for your heip
Hi guess you need to give us more information about the tractor the numbers you posted are not good numbers the ID no oo1215 on the chassis could be the serial number but the other number comes up with nothing and I can find no Simplicity 40 40 there was a Simplicity 4040 built in 1972 powered with aqn Onan ccka 16.5 hp engine. It originally would have had a decal on the hood saying PowrMax
Is your tractor like that if not what does it say?
GB in MN
