I am one step closer to getting my plow-trac to actually move on its own power. The gear shifter was rusted up pretty good but I was able to free up all the moving parts. I am questioning the spring that is attached to the side of the gear box. Is this spring in the correct location? I have seen a few pics and the spring seems to go straight down from the gear shifter,not run along the side of the gear box. Also, according to the parts diagram there is suppose to be a spring inside the gear box as well. It does not however show where that spring should go.
Does anyone know the correct location of these two springs that are on the parts diagram? Does anyone know what size springs they should be?
Thanks
Thanks
