So I got a call today for ma woman who has this LT145 that would not start. I could jump across the 2 big post on the solenoid and make it start. But could not do that from the small ignition start wire to the battery so I know the solenoid was bad. Install new solenoid and could start it with the small wire to the battery but no other way. Checked for safety switches and found 2 that are wire so each has to work. One is the seat safety and the other is the brake peddle safety. I was able to unhook the brake pedal safety and use a couple jumper wires so she could start it and mow her grass but I need to at least try to make it so it is correct. But some how since the 2 safety switches are wired so both have to work or no start I may have to replace them both but sure would be nice to be able to trouble shoot them. Any body have a wiring diagram fro those 2 switches??
Thanks
Thanks
