Dave Sherburne, NY
I'm in the process of building a truck out of a Montgomery Ward/Gilson front end and a Cub Cadet hydrostic rear end. The right angle gearbox on the Gilson went bad about the same time the transmission on my John Deere 112 tractor went bad. I took the trans from the Gilson and by changing the trumpets on the trans mission the Gilson fit right onto the JD and in the process got rid of those worthless splined hubs on the origional JD transmission. So my question is this, in the picture of the CC hydro transmission there are two fittings at the front top of the transmission that I think were connected to a hydraulic lift on the CC tractor. Can I just cap these fittings or replace them with plugs ?
