Tom in Ga
I am having trouble removing the belt pulley from the crankshaft on this mower. Does it have a set screw or something that I am overlooking. I have tried to use a gear puller with no results. Thanks for any suggestions. Tommy
Have you removed the bolt on the end of the crankshaft ? They usually don't come off that hard with a puller . Hope this helps .
