eaton 11 hydro adj.
hello there to all,, neighbor brought over his sears ff/24 garden tractor for help ,,the problem is that when he puts it in neutral the tractor will creep forward or backwards...i have never worked on a hydro. but i would have to be a adjustment to reset whatever it is that is not holding the neutral position..any help,, or site to see how to re adjust this linkage or whatever it would be greatly appreciated,,
The best way I have found to adjust them is to block the drive wheels off the ground, start it up, and put it through the motions.
That way you can take your time, study the movements, and you will see the problem.
That it sometimes goes forward, and sometimes backward, is a sign of something loose or worn, usually in a external linkage.
Take your time, make small adjustments, shouldn't be too difficult.
