gregww
I found a Massey Ferguson 1450. I called the guy and he gave me the model and spec number from the engine. My model number is K321S. His model number is K321A06. My spec number is 601500. His spec is 60320. I looked at a parts list and the part numbers for the heads for both motors are the same. I am hoping the basic motor is the same. Can anyone verify that it is or isn't? Thank you. Greg And by the way, the guy is going to deliver it for me. It runs and has a snow blade and wheel weights.
If you can get a hold of a Kohler parts manual it'll break down what's different between the motors. In Kohler speak K321 K series engine 32 cubic inches 1 cylinder so the basic engines are the same. The spec
number will tell you things like crank shaft size and length, what kind of starter and ignition (although the AO6 vs S may designate what starter and charging system) oil pan depth (some lawn/garden tractors
had a shallow pan to get the crank height right for a particular tractor frame) dip stick type and location, air cleaner variations, fuel tank/fuel pump configuration.
