jd 318 garden tractor
john civi
New User
I have a jd 318 which I had replaced the onan engine with a kohler,this was a conversion kit I installed four years ago and now it will not start the battery is new,the solenoid and starter were bench tested and work,the ignition switch is new and all the safety switches test good. but when you turn the switch to start nothing happens. any ideas?
Circuit breaker or in-line fuse?
The PTO switch is on? The yellow wire at the switch has burnt through the butt connector?
