TractorLinks.com
Steering Wheel removal,Ariens 934
dziadzu
05-15-2017 12:58:28
In order to put a relay in, the dash must come off, thus the steering wheel must be removed. I can't for the life of me, get the steering wheel off. I've soaked it in oil, hammered on it etc. Is there a metal liner between the plastic of the wheel and the steering shaft? If not, I'm going to cut a chunk of the plastic out but preserve enough of the plastic to keep the wheel usable. Any suggestions?
jeffcat
05-16-2017 20:02:06
 Re: Steering Wheel removal,Ariens 934 in reply to dziadzu, 05-15-2017 12:58:28
Hope this might help. If you have easy access to the back of the dash. Remove gas tank and anything in the way. Carefully use heavy tin foil or soaking wet rags. Cover everything you can protect.. Take your propaine tourch and heat the shaft from behind. NOT... super hot but just as much as you dare. You will need someone else doing the pulling on the wheel. Give it a very good look over before you try this. Hope it works.
