farmerjohninpa
i have a ff/24 sears with a loader on it. a friend dropped it off to get it running.i found more water in tank then i did gas, and the points look like a set of well used snow chains. after cleaning the fuel system , it fired up but but definitly the next step is the carb,,but i cannot see any numbers on it to get a kit.. the only thing that stands out is that the bolts that hold it on the intake are on the bottom and i need to remove the intake with the carb.! the model number is t 260g -ga024/3851a,,,,the serial is a813549776 no parts any where near me can you point me in a good direction to obtain them [points , carb kit , condenser , etc ] thanks andlook forward to your reply. may God bless you and yours,,john
